DIY Mercedes W201-190
Automatic transmission
Auto gearboxes, new generations...
Buna seara !
In primul rand, trebuie definita notiunea de "generatie mai noua". Estimez ca ai pe masina 722.3 sau 722.4, care au patru trepte, cu a patra in regim de direct drive, adica 1:1.
Esti nemultumit de ce anume, in legatura cu cutia ta ? Probleme de functionare/fiabilitate sau faptul ca are doar patru trepte ? Simti nevoia de o a cincea treapta care sa fie subunitara, adica overdrive ? Alte motive ?
Exceptand faptul ca nu vor potrivi pe blocul tau motor, generatia noua de cutii automate de la Mercedes, NAG1 (722.6) este gestionata electronic, si nu vrei asa ceva pe masina ta:
Mercedes NAG1 / WA580 / W5A580 automatic transmission by Michael Dickens The NAG1 (WA580 or W5A580) automatic transmission found in many Chrysler products is an electronically controlled 5-speed transmission system with a lock-up clutch in the torque converter. The fifth gear is designed to...
But was afraid to ask BuilderBill :D I finally got the valve body from Bill today to disassemble Look who makes it. Upon visual inspection I find lots of little broken pieces and shavings in various nooks and crannys Comming soon more pics LOL Thanks Bill I'll call you soon with...
NAG2 (722.9), cea cu sapte trepte, este si mai complexa, si nu intru in amanunte, oricum nu are rost.
Cu ceva noroc, poate potriveste un 722.5, care este de gasit pe W124 si (mai rar, parca doar in combinatie cu una din cele patru variante de M104) pe W210, dar vezi mai jos cum arata o lista de DTC-uri, in aceasta situatie:
Chiar vrei sa-ti complici viata fara sa fie neaparata nevoie ?
Dragos
