Emulator blocator volan ML350 W164 din 2010
  • Emulator blocator volan ML350 W164 din 2010
    Am probleme cu pornirea la un ML350 din 2010 , model W164 , si mi s-a zis de catre electrician ca am nevoie de un emulator blocator volan .
    A mai avut careva dintre voi problema similara ?
    Ce emulator am nevoie mai exact ? Trebuie programat emulatorul ? Cum se procedeaza ? Cine a mai trecut prin asa ceva ?
    Cineva mi-a zis ca ML350 W164 din 2010 n-are blocator volan .
    Doua persoane au confirmat ca W164 n-are blocator volan .
    Dar electricianul mi-a zis ca am nevoie de emulator pentru blocator volan .
    Cum aflu daca am blocator volan sau nu ?
      Alt mecanic specializat pe mercedes mi-a zis ca are : blocator volan electric .
        Cum pot sa aflu 100% daca are blocator volan sau nu ?
        Pe placuta cu seria de caroserie scrie : Made in USA ? Inseamna ca a fost fabricat in SUA ?
          Daca pe placuta cu seria sasiu scrie : " Made in USA " , inseamna ca a fost fabricat in SUA ?
          Se poate ca modelele W164 fabricate in SUA sa aiba blocatoar de volan electronic ?
          Pe site-ul de mai jos asa apare ca modelul W164 are : " Electronic Steering Lock (ESL "
          Mercedes W204/A207/W164 | 06-14 | Electronic Steering Lock (ESL) Emulator
          We Provide Best in USA Engine Computer Module Diagnostics, Cloning, Tuning, Programming Service, as well as refurbished ECM replacements. Call Today: (888)541-6025
          This is a brand new Electronic Steering Lock (ESL) Emulator for W204/A207/W164 Mercedes Benz.
          Model C-Class, E-Class, GL, ML, R-Class
          Mercedes Electronic Steering Lock Emulator
          2006-2014 | W204 / A207 / W164
          This ESL Emulator steering lock replacement is for your Mercedes W204/A207/W164. This module is specifically designed for your vehicle to replace a failing ESL, Plug & Play! After shipping us your parts for programming, connect this emulator it place of your OE ESL and that’s it! ECU Team Corp offers the best solution on the market for Mercedes W204/A207/W164 ESL Emulator 2006-2014.
          Mercedes-Benz Electronic Steering Lock (ESL) Emulator
          If your electronic steering lock is malfunctioning, you will not be able start the vehicle (or turn the ignition on). This problem could be intermittent and is caused by a small failing servo inside of the OE ESL itself. Repairing this module is not economically efficient and also very unsafe as the steering column may lock up while driving.​
            Sper ca te-ai lamurit cu blocatorul de volan la W164... Ucide te rog electricianul care a spus ca are blocator
              Bafta multa
