problema e240
  • problema e240
    salutare
    am un mercedes e 240 w211 si de 2 luni nu stiu ce sa ii mai fac.a inceput sa porneasca foare greu la rece,asata nu e chiar asa de deranjant,dar in mers cand o accelerez brusc se opreste.am fost cu ea la tester si au zis ca e debitmetru.am schimbat cum au zis ei si aceeasi problema.de fiecare data cand face asa imi da acelasi cod de eroare P2004(debitmetru(film cald)).daca accelerz usor merge fara probleme.am fost cu ea la diferiti mecanici dar fara rezultat.are momente numai cand e calda mai merge.
    ce as putea sa ii mai fac sau sa imi recomandati pe cineva. multumesc
    Google spune ca la MB P2004 poate sa aiba mai multe interpretari.
    Eu zic sa incerci si cu alt tester...
    P2004 B2/5 (HFM sensor)(P0100)
    P2004 B2/5 (Hot film MAF sensor)(P0100)
    P2004 check external voltage supply.Battery voltage too high
    P2004 check external voltage supply.Battery voltage too low
    P2004 check external voltage supply.Control of holding relay K40/7km (relay CDI)
    cutoff too early.
    P2004 check external voltage supply.KI.15:hardware (HW) turn-on;CAN-BUS turnoff
    P2004 check external voltage supply.Relay (diesel engine voltage supply relay) cutoff
    too late.
    P2004 Component N15/3(ETC control module) is faulty.
    P2004-001 B18 (high pressure sensor) signal,positive/wire open cause short [P0108]
    P2004-002 B18 (high pressure sensor) signal,overload short [P0107]
    P2004-004 B18 (high pressure sensor) signal,engine off B28 (pressure sensor) signal
    and B18 (high pressure sensor) signal different[P0106]
    Read more: http://mbworld.org/forums/c-class-w2...#ixzz2fcYLsWpp
