SBC cod eroare C249F
  • SBC cod eroare C249F
    Va salut dragi colegi, anul trecut cand am achizitionat masina (w211, 270 CDI) aveam o eroare in bord, am fost la un meserias si mi-a spus ca am eroarea C249F.
    Am fost la reprezentanta dar nici poveste sa schimbe SBC-ul, m-am interesat in stanga si in dreapta sa vad cum se poate rezolva aceasta problema pana ce am dat de un meserias care mi-a spus ca se poate resofta de doua ori.
    Ieri la 9 eram la acest service auto, omul pus pe fapte mari intr-o ora mi-a rezolvat problema. Cost 400 ron sau daca i se trimite SBC-ul 300 ron.
    Pentru cei interesati d-l se numeste Gombos Sandor, tel 0740641287.
    Toate cele bune.
    Am gasit aceasta informatie si am zis sa o adaug aici pt a avea cunostiinta de cauza aparuta, faceti abstractie de numele firmei ce apare printre randuri.
    E Class W211/R230 SBC Repair CODE C249F
    Mercedes E Class W211/R230 SBC Repair CODE C249F
    Mercedes E Class W211/R230 SBC Repair CODE C249F - Sensotronic Brake Control (SBC)
    If you own a Mercedes E Class W211 or SL R320 and have a brake error, then you must replace the SBC unit which can be very expensive from the dealer.
    Please note, we can only repair the fault electronically and not the physical hydraulic. It is recommended for the car to be present at our workshop to confirm a successful repair.
    The SBC module counts breaking cycles, after exciting the value of approx 300000 , an error message occurs.
    It’s a kind of protection for the electro motor inside the aggregate.
    So far we had no problems, we’ve tested the first module over 2 years ago, reset this and reused in a car sucessfuly.
    This is an exclusive service by Revtronic, carried out at our workshop. As many claim that a new unit must be fitted.
    The SBC will have to be removed and sent into us.
    The unit has to be disabled before removing.
    Errors reported:
    SBC Control module failure
    STOP displaying on instrument cluster
    Brake defective stop vehicle (Normally displayed on the screen)
    Mercedes E Class W211/SL R230 SBC Repair CODE C249F
    OPERATING TIME OF COMPONENT A7/3 IS EXCEEDED (SBC HYDRAULIC UNIT) ON A W211 MERCEDES E220 CDI FAULT CODE IS C249F
    We have successfuly repaired the following Bosch Part Numbers:
    Mercedes E Class W211/R230 SBC Repair CODE C249F - 0 265 960 012 (0265960012)
    Mercedes E Class W211/R230 SBC Repair CODE C249F - 0 265 960 013 (0265960013)
    Mercedes E Class W211/R230 SBC Repair CODE C249F - 0 265 960 015 (0265960015)
    Mercedes E Class W211/R230 SBC Repair CODE C249F - 0 265 960 018 (0265960018)
    Mercedes E Class W211/R230 SBC Repair CODE C249F - 0 265 960 019 (0265960019)
    Mercedes E Class W211/R230 SBC Repair CODE C249F - 0 265 960 020 (0265960020)
    Mercedes E Class W211/R230 SBC Repair CODE C249F - 0 265 960 023 (0265960023)
    Mercedes E Class W211/R230 SBC Repair CODE C249F - 0 265 960 025 (0265960025)
    You now have 2 options for Mercedes E Class W211/R230 SBC Repair CODE C249F service :
    You can call our workshop and arrange for your Mercedes E Class W211/R230 SBC Repair CODE C249F to be repaired at our workshop. There is no need to remove the SBC . Using special diagnostic hardware we can reset this fault. This will save alot of time and labour , no need to remove SBC.
    Carefully remove the SBC control unit , there is a special way to remove the SBC, you will haev to de-activate the pump first. There is also a very special procedure to refit . Taking to an independent specialist is highly advised.
    Here is the location:
    There is a special procedure to remove the SBC unit. Please take your car to a qualified technician. If uncertain on how to remove the SBC unit , please contact us.
    Please contact us if your part number is not listed.
      Foarte buna informatia @gmihai24.
      Bravo, cel putin acum sunt toate informatiile complete despre acest cod.
      Toate cele bune.
        "The SBC module counts breaking cycles, after exciting the value of approx 300000 , an error message occurs." Asta inseamna ca masinile noastre dotate cu acest sistem sunt un fel de bombe cu ceas.Am studiat si eu forumurile straine si toti se plang de acest sistem.Totusi sunt curios cam la ce numar de km sa ne asteptam sa cedeze SBC-ul, pe scurt cam in cati km atingem valoarea aia de 300000 de "franari".
        *Smart Fortwo 451 Passion
        *w123 230CE
        *w211 E270 cdi Avantgarde
        *w203 c220 cdi Avantgarde
        *w215 CL55 AMG
        *w202 C180 Esprit
        *w210 e320 162kw 1996 Avantgarde
        *w202 c250 TURBODIESEL 110kw 1998 Elegance
        *w201 190E 2.0
        *w123 langversion pullman
          Este numai un mod de a mai schimba ceva pe masina, eu am doua resetari deja si 100 mii peste si nu are nici o treaba sbc-ul, partea mecanica se defecteaza mai greu si doar electronica te anunta ca ai folosit cam mult sbc-ul si fara frane nu ramane doar va fi pedala mai greu de apasat.
            Toate cele bune.
            Parerea mea ca ai luat teapa.
              Va rog frumos, am citit nenumarate posturi despre acest SBC. Poate sa-mi explice si mie cineva ce este si cu ce se maninca... asa ca la prosti? Am inteles ca face parte din sistemul de franare, dar ce face in mod exact nu stiu. Multumesc
              Tel. 0736375626 Marian
                Uita-te aici ca sa intelegi mai bine. http://www.youtube.com/watch?v=RtWU17NLgfA
                  Multumesc mult In mare parte am inteles ce face SBC-ul.
                    De ce....?
                      Toate cele bune.
                      Depinde de service.
                      SBC-urile sunt de mai multe feluri/modele (in functie de seria care este scrisa pe el, unii au altii nu-l au) soft-ul necesar rescrierii SBC-ului (in cazul meu reprezentanta din Pitesti l-a avut).Cei de la Craiova ziceau ca nu se poate resofta, desii, cei din Pitesti mi l-au resoftat (mi-au adus la cunostiinta in scris ca exista posibilitatea sa se blocheze de tot (in timpul resoftarii) si sa nu-i mai poata face nimic).
                      Dupa resoftare (pana in 200 lei), pentru a-mi oferii garantie mi-au schimbat si lichidul de frana (2-300 lei, nu mai stiu exact).
                      Asa ca nu trebuie sa intrii in disperare atunci cand iti apare eroarea cu sbc... (nu mai stiu exat cum era). Totul este sa mergi la service cand este pe fond alb, atunci cand iti scrie cu rosu este cam mare problema din cate am inteles (adica exista riscul sa nu se mai poata resofta/reseta).
                      Calculatorul are un numar de apasari de frana, un mumar finit (de ordinul sutelor de mii, sau milioanelor, nu stiu), asa mi-au spus baietii de la reprezentanta din Pitesti (mi s-au parut net superiori in calitatea serviciilor fata de cei din Craiova).
                      In legatura cu cei care au sau nu service-uri autorizate sau nu, exista cativa oameni in tara care stiu sa le resofteze (dar nu-ti ofera garantie), este un domn Cristian (la Iasi daca nu ma insel), ''Mercedes-CDI" aici la noi pe forum (din Constanta), acesta din urma zicea ca-i poate scoate inclusiv din eroarea aparuta pe fond rosu, mai este un domn Daniel la Tg. Jiu (acesta din pacate nu avea softul pentru modelul de sbc care il aveam pe masina mea) el mi-a recomandat sa sun la reprezentanta la Pitesti.
                      Oricum, nu recomand sub nici o forma (la probleme mai ''delicate'' reprezentanta din Craiova).
                      Eu schimbul de ulei la CVA l-am facut la domnul 'Automaticul' , iar sbc-ul la Pitesti, dupa cei din Craiova, trebuia schimbat si nici vorba de schimbat pe gratis (invocand defectul de fabricatie).
                      Toate cele bune!
                        Astăzi încă un posesor de W 211 a plecat fericit sper casa , SBC-ul ia fost resetat !!! Avea doua erori C249F+C2498 !!!!
                          Cunoasteti pe cineva la Cluj care se pricepe la reinitializarea SBC-ului?
                            La Cluj nu..!
                              Originally posted by caesar View Post
                              Cunoaste-ti pe cineva la Cluj care se pricepe la reinitializarea SBC-ului?
                              Este si la Cluj . Ai PM .
