W202 1994. As vrea sa stiu cum se demonteaza tetierele din spate. Va multumesc.
					Demontare tetiere spate
Te-as ajuta dar nu am tetiere in spate pe masina
Sa vedem ce ne da internetul...
pentru W201
"1. Make sure that the head restraint is in the vertical position.
2. Push the plastic covers at the base of each head restraint stalk
forwards, then use a screwdriver either side to press in and release the
cover securing tabs. Slide the covers out of position and up the stalks
(see illustrations).
3. Use a small screwdriver to lift the small black locking levers now
exposed (see illustration). The levers need only be lifted very slightly,
as the 'removal' position is between the two locked positions.
4. Pulling gently on the head restraint, slide it to the rear and out of
the guides.
The illustrations for part 2 show what looks like a fairly simple
operation removing the small plastic covers that the metal support rods
slide into and out of when the head rests go up and down.
The illustration for part 3 looks a little more intricate, sticking a
screwdriver into the hole to flick a tiny lever. As you look down on the
hole from sitting on the back seat, the lever appears to be in the top
right area of the hole. It may be mirror image on half of the holes, and
therefore in the top left. "
Sper ca sti ceva engleza ca nu am timp sa traduc. Mai era un thread pe benzworld dar era la un w203. Ca fapt divers merita facut un cont acolo daca sti engleza.E220 cdi W210, 2001
E320 W210, 1997
C180 W202, 1994
poate te ajuta mai mult clipul acesta,este pentru w210 dar cred ca asa e si la tine:
demontare tetiere fata si spate
http://www.youtube.com/watch?v=PdOxZ...e=channel_page.
Daca nu merge sa deschizi scrii pe youtube:w210 demontare tetiere.Last edited by gigi_herseni; 01-28-2010, 18:43 PM.
Mersi frumos. Am reusit, in sfarsit, sa le scot. E exact ca in filmuletul respectiv.Originally posted by gigi_herseni View Postpoate te ajuta mai mult clipul acesta,este pentru w210 dar cred ca asa e si la tine:
