Ajutor... cod culoare
  • Ajutor... cod culoare
    Tocmai mi-a busit sotia masina si as vrea sa ma ajuta-ti cu codul de culoare .
    VIN WDB1241261J019503
    Model 250 D
    Chassis 1241261J019503
    Engine 605911 10 002352
    Transmission 717413 06 382600
    Order 0 2 543 34322
    Approx. year not defined
    Dealer Italy (543)
    Interior (cloth) fabric black+anthracite+graphite (001)
    Paint
    744 brilliant silver metallic (? 1991)
    Options
    240 outside temperature indicator (? 01.03.1982)
    second spare wheel (? 01.01.1964 ?? 28.02.1973)
    280 trunk set, 3-piece (? 01.09.1964 ?? 31.08.1972)
    steering wheel (400 mm dia.) and gearshift lever in leather trim; on W202 390 mm dia. (? 01.05.1984)
    305 fan clutch (? 01.02.1963 ?? 30.09.1970)
    dust filter (? 01.11.1990)
    341 additional lamp (? 01.09.1982)
    additional turn signal lamps for Japan, Denmark, Italy and national code 837 (? 01.08.1970 ?? 30.11.1976)
    special version for export to cold countries (? 01.05.1967 ?? 29.02.1968)
    430 headrests in the rear (? 01.01.1977)
    safety belts, front and rear (? 01.01.1964 ?? 31.05.1973)
    524 Reims adapter IV (? 01.04.1962 ?? 28.02.1963)
    paintcoat preservation (? 01.01.1964)
    570 folding armrest front w202/210 stowage box front with armrest (? 01.04.1970)
    front folding armrest w202 - housing at front with armrest
    587 front folding armrest
    single seats with folding armrest (? 01.01.1963 ?? 30.09.1970)
    automatic climate control and electric window lifters (front doors) (? 01.01.1977)
    593 headlamp flasher and turn signal lamps - italy (? 01.01.1963 ?? 31.07.1965)
    headlamp flasher and turn signal lamps, front, crystal clear (? 01.08.1965 ?? 31.01.1967)
    heat-insulating glass, rear window pane (? 01.02.1967 ?? 31.01.1971)
    heat-insulating glass, all-around, heated rear window pane (single-sheet safety glass), band filter
    green heat-insulating glass all round, heated rear window, single pane safety glass - tinted strip (? 01.01.1972)
    620 emission control system
    ECE version with catalyst technique (? 01.09.1983 ?? 28.02.1985)
    vehicles with catalyst technique (? 01.03.1985)
    version for Italy (? 01.01.1967 ?? 31.08.1969)
    630 ECE warning triangle (? 01.08.1980)
    radial-ply tires (? 01.03.1966 ?? 31.10.1974)
    Michelin x tires (? 01.08.1963 ?? 31.08.1965)
    731 wood trim, burred walnut root (? 01.08.1980)
    859 model update ii (? 01.01.1978)
    877 reading lamp in the rear (? 01.11.1963)
    Vezi codul de la Paint.
    Acum vad ca e vb de un accident. Te duci la reprezentanta si ceri detalii suplimentare daca e cazul.
      744 brilliant silver metalic
