Turatiile trepdieaza in mers
  • Turatiile trepdieaza in mers
    Salutare!
    Am o problema interesanta si enervanta in acelasi timp
    Masina: A180 W169 cdi din 2008
    Problema: Cand incerc sa mentin viteza incepe sa imi trepideze turatiile.. in sensul ca se misca acul sus jos in loc sa mentina rpm. daca accelerez sau iau piciorul de pe acceleratie totul e ok.
    Chestia asta se intampla uneori, nu mereu, si dispare in momentul in care imi intra in limp mode. Opresc masina si repornesc, iese din limp mode totul ok, dar problema tot persista uneori.
    Recent am avut in bord si check engine.
    Erorile de care am dat dupa ce am verificat cu un obd:
    1. ============1==============
    2. P2133
    3. Raw code: 2133
    4. ECU: Engine control unit
    5. Status: Validated and stored in non volatile memory, Validated fault present at time of request
    6. OBDII: Throttle position (TP) or Accelerator pedal position (APP) sensor/switch F - high input
    7. ============2==============
    8. P2135
    9. Raw code: 2135
    10. ECU: Engine control unit
    11. Status: Validated and stored in non volatile memory, Validated fault present at time of request
    12. OBDII: Throttle position (TP) or Accelerator pedal position (APP) sensor/switch A/B - voltage correlation
    13. ============3==============
    14. P2136
    15. Raw code: 2136
    16. ECU: Engine control unit
    17. Status: Validated and stored in non volatile memory, Validated fault present at time of request
    18. OBDII: Throttle position (TP) or Accelerator pedal position (APP) sensor/switch A/C - voltage correlation
    19. ============4==============
    20. P2355
    21. Raw code: 2355
    22. ECU: Engine control unit[Archive (inactive)]
    23. Status: Validated and stored in non volatile memory
    24. OBDII: Cylinder pressure sensor, cylinder 10 - circuit high
    25. ============5==============
    26. P2511
    27. Raw code: 2511
    28. ECU: Engine control unit[Archive (inactive)]
    29. Status: Validated and stored in non volatile memory
    30. OBDII: Engine control (EC) relay, sense circuit - circuit intermittent
    31. ============6==============
    32. P0401
    33. Raw code: 0401
    34. ECU: Engine control unit
    35. Status: Confirmed
    36. OBDII: Exhaust gas recirculation (EGR) system - insufficient flow detected
    Crezand ca problema e de la pedala de acceleratie am schimbat-o cu un de la dezmembrari, insa problema tot persista
    Cum as putea sa rezolv problema? Am inceput sa o dezemembrez dar e foarte multa bataie de cap avand in vedere ca piesele sunt foarte inchegate intre ele
    Ma gandeam ca ar fi clapeta de acceleratie, dar ma gandesc sa nu ma apuc sa o schimb si sa am aceeasi problema in continuare.
    Poate fi si de la filtru particule?
