probleme cutie a 150
  • probleme cutie a 150
    Am si eu o problema cu un a class 2005 cutie automata ..o pornesc o pun in drive pleaca bine dupa loc schimba vitezele si cam in 4 km cutia intra pe avarie si numai merge mai mult de 60 km la ora daca opresc si pornesc iar motorul aceeasi poveste ..a mai avut cineva probleme ce asa gen cu cutia de viteze cam cat mar costa reparatie ..o zi buna
    am fost cu masina la un tester si codurile de eroare sunt
    00D4 Fault is stored in component FCVT. [P0793]
    00C3 Fault is stored in component FCVT. [P0730]
    00D2 Fault is stored in component FCVT. [P0710]
    D408 The stop lamp switch signal from the traction system is not available on the CAN bus. ( CAN timeout fault )
    0722 The signal from component Y3/8n3 (Output speed sensor (VGS)) is not available. Read and observe repair information.
    0793 The rpm signal from component Y3/9b4 (CVT (continuously variable automatic transmission) secondary rpm sensor) is not available.
    0896 Impermissible adjustment of the step-down ratio in the continuously variable automatic transmission (CVT)
    2722 Impermissible closing of hydraulic brake 'Reverse gear' has occurred in the continuously variable automatic transmission (CVT) when selector lever position "N" was engaged.
    C401 One or more signals sent from control unit Engine management via the CAN bus is implausible.
    2731 Impermissible closing of hydraulic clutch 'Forward gear' has occurred in the continuously variable automatic transmission (CVT) when selector lever position "N" was engaged.
    0894 The gear is implausible or the transmission is slipping.
    2790 Torque intervention occurred in the engine control due to overspeeding of the secondary disk set in the continuously variable automatic transmission (CVT).
    astept o parere mersi
    O gramada de erori. Cum ai rezolvat?
