Salut!!! Poate cineva sa-mi spuna unde se afla pozitionat sensorul de temperatura motor? A class 1400.Am cumparat unul nou si nu gasesc unde sa-l montez.Multumesc frumos.
senzor temperatura motor
Sper sa fie varianta corecta.
This sensor is impossible to photograph due to its location I suspect also that it would be impossible to get at it to replace without again lowering the engine, albeit not by much. To locate it look for the thermostat housing shown in the photograph and then look to the left and back the arrow is pointing in the general direction, you will see there a small corrugated tube carrying the electrical supply to the sensor, it is possible to just see and feel the sensor.
Consideration to replacement of parts such as this on this car seems to have been completely over looked in the design & development stages with the result that the engine now needs to be mounted on elastic for ease of removal.
Seara buna!Originally posted by rapid18 View PostSalut!!! Poate cineva sa-mi spuna unde se afla pozitionat sensorul de temperatura motor? A class 1400.Am cumparat unul nou si nu gasesc unde sa-l montez.Multumesc frumos.
Senzorul se afla montat pe termostat. Ca sa gasesti termostatul, urmareste furtunul gros ce vine montat pe radiator in partea dreapta( cum privesti masina). Furtunul ala gros care intra in radiator, in partea dreapta, vine direct din termostat. E cel mai simplu asa...
Am atasat o fotografie a unui termostat:
Numai bine!Last edited by LauLaur; 11-08-2018, 18:59 PM.Ceea ce nu ma distruge ma face mai puternic!
senzor temperatura aer admisie
Salut!!! Multumesc pentru raspunsuri dar nu este acela pt ca trece antigel prin el,ce am eu este senzor temperatura aer admisie daca se poate sa-mi spuneti unde e.http://www.autokarma.ro/generateimg/produsBig/2055371
Pai daca ai spus senzor temperatura motor altceva nu poate trece prin el decat lichid de racire. Ai primit raspunsurile corecte pentru ceea ce ai cerut.
Asta-i cu totul "alta mancare de peste". Depinde din ce an de fabricatie este masina ta. De obicei senzorul de temperatura al aerului admis este incorporat in debitmetru.Salut!!! Multumesc pentru raspunsuri dar nu este acela pt ca trece antigel prin el,ce am eu este senzor temperatura aer admisie daca se poate sa-mi spuneti unde e.http://www.autokarma.ro/generateimg/produsBig/2055371
Mai jos, in fotografii este incercuit senzorul. Mai multe informatii gasesti si aici: http://www.aclassinfo.co.uk/mypage.38.htm
Toate cele bune!Ceea ce nu ma distruge ma face mai puternic!
Salut!! Am desfacut debitmetru si nu este acolo sa inteleg ca l am cumparat degeaba? Eu l-am comandat dupa seria de sasiu a masinii,normal nu era sa nu-l mi gaseasca? Dar asta e...oricum iti multumesc mult de tot pentru ajutor tot respectul pentru tine!!!
Debitmetrul e lipit pe placa ECU. In acelasi corp cu debitmetrul este si senzorul de temperatura al aerului admis. La modelul tau, cat si la al meu, senzorul ce l-ai cumparat tu nu se potriveste. Avand corp comun, ar trebui schimbat cu tot cu debitmetru, dar ... Si eu am vrut sa-l cumpar, dar m-am potolit repede.
In fotografiile atasate de mine se observa "filamentul" de care vorbeai tu, este de fapt un termistor.
Cred ca ti-au cautat piesa, mai degraba, dupa codul motorului. Vezi daca ti-l primesc inapoi.
Bafta multa!Ceea ce nu ma distruge ma face mai puternic!
